An air oil cooler is used for cooling hydraulic circuits by passing ambient air over the cooler using a fan driven by an electric or hydraulic motor as a coolant.
The core of the cooler, made of high tensile aluminum alloy, is produced by a vacuum brazing process. The design of the tubes increases the turbulence of the fluid and thus also the cooling capacity. In addition, the presence of special turbulence disks on the finned surfaces of the cooling component improves the overall heat transfer coefficient. The result is a compact, lightweight and robust product with advanced technology.
The core
The core of our air oil coolers is made of an aluminum alloy. This construction ensures good durability and efficiency. The unique design of the tubes increases the turbulence of the fluid, which increases the cooling capacity and minimizes the risk of overheating in the system.
Our air oil coolers are designed for cooling hydraulic circuits by using ambient air as a coolant. By directing air over the radiator by a fan driven by an electric or hydraulic motor, reliable and efficient cooling is achieved, ensuring optimal operating temperature of the hydraulic system. To maximize cooling performance, the finned surfaces of the cooler are equipped with special turbulence disks, which further improve the heat transfer coefficient. This makes our air oil coolers an advanced, compact and lightweight option for demanding industrial machinery applications.
Advantages of EMMEGI air oil coolers
Efficient cooling: Optimized design to maximize heat dissipation and prevent overheating.
Long lifespan: Durable material and robust construction for lasting performance.
Lightweight and compact: Designed to provide a flexible and space-saving solution.
Versatile use: Ideal for hydraulic systems, compressors and other industrial applications.
